0
0
Hello
My AKCP SENSORPROBE2 PoE V2.0 does not display negative temperature it writes 1128.
Thanks
  • You must to post comments
1
1
Hello,
OK, your unit is the SP2 and not the SP2+. Please upgrade your units firmware on our website support portal. You an access this here;
If you have any issues after upgrading please contact me at support@forum.akcp.com.
Regards,
Scott
AKCP Technical Support Manager
0
0
Hi!
I’ve contacted the support. They will answer shortly.
0
0
Hello,
Can you please confirm if your base unit is the SP2 or the SP2+? Or you can send me the MAC ID and I can check it.
Thanks
AKCP Support
0
0
sensorProbe2 PoE v2.0 SP2474 080917
Mac: 00-0B-DC-01-26-67
Showing 4 results
Your Answer
Please first to submit.
