Hello AKCP,
I see in my SPX+ and SP2+ units there is this feature called SMART SENSOR RECOVERY. Can I use this on all AKCP sensors and when should I use this feature?
Thank you!
Hello AKCP Customer,
No, not all of our sensors are compliant with the Smart Sensor Recovery feature.
Here is the list of the AKCP sensors supported using the smart sensor recovery feature;
- SHL and SHL-DA
- CTHMSv2 with SSB and CCM
- THMSv2 with SSB and CCM
- CCM only
- ILPM(All variants)
- BATTMON
- CTHMSv1 and CTMSv1
- LCD-TMP and LCD-THS
- TMSv1 and THMSv1
- DPTHMS(CAS)
- SSL
The reason for using this feature is if there are problems with any of the sensors noted above, these could be in accurate readings, sensor errors etc. You would first upgrade your SP+ unit to the latest firmware on our website. Then follow the steps after clicking on the button shown above.
If you try and use the sensor recovery feature on a non-smart sensor that is not in the list above you will receive an error message in the web UI;
Or similar error, for example busy if tried on sensors that are not supported.
- AKCP Support Team answered 11 months ago
- last edited 11 months ago
