Hello AKCP Team,
We were wondering if your AKCP E-sensor8 & E-opto16 expansion units are compatible with the SP+ units and if so, how are they connected?
Thanks in advance.
- asfscott asked 2 years ago
Hello AKCP Customer,
Thank you for your questions. Yes both of the expansion units E-sensor8 and E-opto16 are compatible with the SP+ units. These are connected to the SPX+ EXP port, and the SP2+E port. They will not work if connected to the SP+ sensor port(s).
They also require connecting their external AC power adapters in order to function properly. Also keep in mind the E-opto16 connections require a DC power source as they are true “dry” contact inputs.
Please also check the expansion unit manuals located on our website support portal for more details. https://forum.akcp.com/support-center/customer-login/
Please contact our support team if you have any further questions or need technical support.
