0
0
Hello, I would like to know if there is any possibility to connect via MQTT connect my sensor probe 2+ ,to Datacake, TTN, or AWS. If you have information about this, please message me at my number 6932-4861.
  • You must to post comments
1
1
Hello Rolando, thanks for your question. We do support MQTT and MQTTS, so there should be no problem integrating to any platforms that support this. In fact we recently did integration to MS Azure via MQTT. You can read about that here
https://forum.akcp.com/articles/akcp-microsoft-azure-cloud-compatibility/
Our support team will also post more details and links here on how to setup MQTT on our devices.
1
1
Hello Rolando,
Please check and follow the instructions in this link to the pdf below that will allow you access to our website support portal where you can then download all of our product manuals including the MQTT feature.
Please check the details outlined in our SP+ and WTG MQTT Manual.
Also, just to mention, please check this direct link on our website which includes many details and FAQ’s on our SP+ units;
https://forum.akcp.com/knowledge-base/sensorprobe-plus-series-knowledge-base/
If perhaps you do not have any of our base units yet, here is the direct link to this manual;
http://www.akcp.in.th/downloads/Manuals/MQTT/SP+%20and%20WTG%20MQTT%20Manual.pdf
Thanks,
Scott
AKCP Support Manager
Setup of AKCP Support Page manual
Showing 2 results
Your Answer
Please first to submit.
