Hello AKCP,
Can you please explain in detail about how many temperature sensors a typical data center needs and where they should be installed?
Thanks!
AKCP Dealer
- AKCP Support Team asked 2 weeks ago
Dear Valued AKCP Dealer,
Thank you for your questions on this. Please see below as we can explain how to plan data center temperature sensor coverage.
A temperature sensor measures conditions at its location. Nearby server racks, hot exhaust, cooling outlets, and open doors can create very different readings within a small area. Effective monitoring starts with understanding those differences.
In this video below, we explain:
- Why temperature sensors have no universal coverage area
- ASHRAE guidance on measuring server inlet temperatures at the top, middle, and bottom
- AKCP’s approach using three front and three rear temperature measurement points per monitored rack
- How rack Delta T—the difference between inlet and exhaust temperature—helps assess cooling alongside airflow and IT load
- Why sensor placement and density matter more than floor area alone
- How monitoring requirements differ between data centers, server rooms, and warehouses
- How AKCP Thermal Map Sensors, Quicklime DCIM, and sensorCFD help visualize temperature gradients and investigate hot spots
Whether you manage a server room, colocation facility, or enterprise data center, a well-planned sensor layout helps identify thermal risks and supports more efficient cooling.
Please also read the accompanying article here:
https://www.akcp.com/2026/08/04/how-m…
We hope this will help and if you have any further questions on this, please contact our support team (support@akcp.com) directly.
- AKCP Support Team answered 2 weeks ago
