Dear AKCP Support Team,
Our customer is asking if you can please help them setup a VPN connection to the APS (AKCPpro Server)?
They also want to have one central site that can monitor multiple sites, is this possible?
Thank you!
AKCP Direct Dealer
Dear AKCP Dealer,
Thanks for your questions on this and please see below for the details on both questions.
When you’re using VPN to connect remote client units to centralized APS installation, only the VPN port needs to be opened publicly for the APS server (default 1194 TCP but this can be customized), all other traffic and protocols will travel within the VPN tunnel, so there’s no need to open other ports.
Note that the APS VPN settings will depend on the user’s choice when setting up the VPN parameters. The default VPN port is 1194 UDP but it can be changed as required.
Only the APS VPN port needs to be opened publicly on the firewall, so that a remote SP+ device could connect to it (see the diagram in the manual below).
Please see the APS VPN manual using the link below. This should answer your questions on how to set this up.
Thank you for your quick response.
Regarding the MODEM, I will use one external USB modem that connects to AKCPro Server computer.
(E-M4G: External USB modem for PC running AKCPro Server)
Regards.
- abdelhadi answered 3 months ago
