Hello AKCP Support & Sales team,
We understand that with the newer versions of the APS these require purchasing the license or specific licenses. Can you please provide us some guidance on this and how the licenses work?
We have some other important questions regarding the APS that our end customer is asking, can you also help on these?
Thank you,
AKCP Authorized Dealer in Austria
Hello Austria!
Thank you first off for being our exceptional representative in your country. We truly appreciate being our partner in providing top quality technical support directly to our AKCP end customers there. Please see below and also the list of Q&A’s included.
Yes, that is correct, the APS versions released after v14 requires the purchase of the licenses.
However, you can download our APS software and install it for free from this link here and activate this online; https://www.akcp.com/akcp-products/akcpro-server/
After your online activation is completed, your license will include the following licenses for no charge that will expire annually after the activation;
APS-HOST’s (SPX+, SP-WTS, securityProbe) = 4 units
3PS-APS (virtual sensors on the APS) = 5 sensors
APSIPCAM (ONVIF IP camera) = 0 IP cameras
TMPT-APS-15 (15 virtual sensors on a single IP address) = 0 sensors
TMPT-APS-25 (25 virtual sensors on a single IP address) = 0 sensors
TMPT-APS-35 (35 virtual sensors on a single IP address) = 0 sensors
APS-HOST-2 (SP2, SP2+, SP1+) = 4 units
APS-HOST-SEN (virtual sensors from SP+ base units) = 0 sensors
APS-BOARD Expansion Units for SP+ (CCU, E-IS8, E-Opto16) = 0 units
Please Note: The expansion units connected to the securityProbe base units do not require any licenses to view in the APS software.
If you require more than the default free licenses above, these need to be purchased. Please check our latest price sheet, contact your local dealer or our sales team directly (sales@akcp.com) for the costs on these using the product codes noted above.
You can also purchase a 1-year unlimited license which includes an unlimited amount of the licenses noted above. This license needs to be renewed annually. Extended licenses can be purchased up to 10 years.
Pop up license expiration notices – Our APS system will inform you with continuous pop-up alerts advising your license will expire soon. You will need to inform your local dealer or us directly if you wish to renew the current license or make changes to this prior to the license expiring.
License Expired – If you, or your customer allows the APS license to expire, you will no longer be able to log in to APS as well as all monitoring of your connected units stop. Your only option is to purchase your license again, as you cannot return back to your default license.
We have added many other frequently asked questions to our online forum here that refer to our APS licenses that we hope will be helpful. So, please check these in the APS category & use the “search” feature to find what you are needing help on. For example, APS licenses, or APS installation etc.
- last edited 9 months ago
